Yo Hoot,
I see what you're saying. The reason I specify using the 11/16th hole saw is that it requires you to thread the fitting down into the tank even before you put the nut on. When I went in search of a bulkhead fitting to use, one guy at a marine supply store said that they just thread the fitting down into the tank and it seals fine without the nut on the back. I realize that's just what they do, and it seems kind of like a jury rig that way, but with the nut on the back, the fitting threaded into the tank, and the o-ring there to back it up, I don't forsee any problems with it leaking.
I've been looking for some other kinds of fittings to maybe simplify this whole kit and make it a little cheaper, but bulkhead fittings are hard to find. I'd like to just cap the factory vent and run a new vent line to the metal vent on the fill neck, but finding a 3/4" bulkhead fitting with a 90 degree bend in it is proving to be a challenge.
