I would like to say I got longer battery life...
Lock Your Doors!
7" EVIC change
Tuesdak
The standard for battery life here in the Phoenix Heat is making it two years. (Some vehicles don't even make much over 1 year.) My last Odyssey set in my 2018 didn't make it two years before a no start (no jumpbox x2 start) dead at 1 year 8 months.
Figure a record breaking number of days in a row of record setting 100+ degree days last year. To counter this I frequently ran the A/C in the garage overnight to cool the batteries/pickup down. I also used a 10A automatic charger to top the batteries off 1 or 2 times a week overnight.
I noticed slower cranking for this winter's lower temps. However my battery tester didn't show anything even testing the batteries while separated. I would call this the two year mark.
February got me a "Service ABS" warning after cranking. Some time on the battery charger made it all well.
March... Now the 67A recall makes short trips worse as the grid heater runs longer in "winter to me" weather. This device is slow to boot and finally display useful info. You can imagine my thoughts, after the gauges finally booted up, about the 11.8V indicating grid heater on, battery SOC, and battery condition.
Yep. Passenger battery dead and murdering the driver side battery. Charging voltage came up quicker than the driver side when charging them disconnected from each other.
Driver side battery No Load:
Load ON:
Tested at the store and both low on CCA's but not bad enough to warranty. :mad: Weirdly charging up just enough to "pass" but loosing enough charge over a couple days to not crank the engine. At least the voltage was high enough to try unlike the past batteries that the ECM wouldn't even attempt a crank.
After another No-Start the passenger battery tested bad. They warranty replaced both. 2 years 5 months out of them. However trouble and fighting them deduct those two months. So 7 months more than the Odyssey with the above extra care.
I used to work on large UPS systems (large battery backup systems for data centers), and heat is the enemy of batteries.
I also applaud you for supporting your local battery retailer.
Did you use this battery?
https://www.odysseybattery.com/products/odx-agm65-battery-65-pc1750t/
Impressive as operating temperature 176°F, much higher then any other battery I've seen so far.
The "Performance" edition of the 94R as they don't make an "Extreme" 94R. They need too... It was a substitution in the supply chain shortage days for the X2.
We are already setting records with 103F temps this year.
You might want to look into these.
Watching the charging voltage on my 2018 Vs. the specs for that... They don't match. Float voltage, 13.6V, is too low and I have seen "too high for this Li batt" 14.9V after a start in the winter.
I should put a temp probe on my batteries and see how hot they get. Li's BMS may cut em out on overheat. o_O
"Fragile" Lithium is actually high on my S! list over the BMS that cuts a battery out: Too Cold. Too Hot. Extended time using all of the CCA's... Used a pair in a mobility scooter. Batteries get low and "CLICK!" scooter stops dead with no warning. (AGM will slow down but move just a little further like out of the way.) Then it takes a "special" charger to start charging at the BMS when cut out at 0V and stay "on" long enough to reset the BMS. Li marketing is also a "LIE" rating it's RC down to 0% charge. This overdischarge damages the Li battery just like Lead Acid overdischarge, but, they get away with it because Li has so many more cycles to 50% or 0% SOC over AGM and flooded Lead Acid.
I looked into Battleborn Li for my RV and the CCA's required for it's Onan generator were a show stopper.
Seriously? I start my Cummins right from LiFePos including a pre heat cycle and you say you can't start an an itty-bitty Generator from it?
I've the impression that 200A for 30 seconds should start that thing.
But anyhow, BB battery's are way overpriced by today's standards.
No way I'd spend 7x the price of an average 100Ah LiFePo battery.
Also I wouldn't use a LiFePo as a starter battery if it is fitted to the engine compartment.
The environment there is just so not for a Lithium battery.
If installed in the Trunk ore somewhere else, maybe.
