Its not that I need a new one, its because with big sticks, and a drag comp when its cold you get too much timing from the ecu, so you need to trick the ecu into thinking the truck is hotter than it is, thus less timing, do a search and you will see this issue comes up during the cold months, its worse with my Drag Comp than my TST, search under IAT bypass.
