Changed oil & fuel filters, key on & off to prime fuel system, started on second try. I let it idle for a few minutes & shut it off, cleaned up for a test drive & it won't engage the starter. The gauge needles bounce when key is turned, shows door ajar and mileage on the evic, radio doesn't light up or work. 12.66 volts at the fuse box all fuses good. Bad ignition switch?
One time when I turned the key the evic briefly said "wrong key fob", tried other key, no change, doors lock & unlock okay.
Would a new switch have to be programmed by a dealer?
Keny
Keny
