I'm "gearing" for a change!
How come when I change my oil........
Just ordered DTT VB!!!!
Hi Folks,
Perhaps some of you remember my saga of the 4. 10 gear set change the dealership was going to make for me. Well, I dropped the Ram off this p. m. and asked to see the new 4. 10s.
They brought me into the service area and showed me a COMPLETE rear end housing they will be swapping on our Ram. Needlesss to say I was both shocked and elated the change was a factory set-up unit in liew of a tech in the dealership setting up the gear set on a bench between coffee and donuts!!!
Now all I have to do is relearn how to drive it, and if the snow ever melts hook up the 5er and go for a ride! #ad
Oh! Did I mention they're footin' the bill! #ad
White 2001, 3500, Auto,3:54 (soon to be 4:10),QC,2WD,LB,34' DBL slide Cardinal 5er
I want you to know that 4:10's are awesome, as I had 3:55's on my last RAM #ad
The only thing I wish DC would offer is the 3:73's! #ad
Y2K Black 3500 ISB 4x4, 4:10 LSD,Auto,QC,SLT Laramie,"EZ",DTT VB,DD2's,LB, Polished Stull Billet Grill & Fog inserts, Chrome Smitty-Built Step Rails, Mopar Chrome-Tipped Mud Flaps, A-Pillar mounted West-Tach Turbo/Pyro/Trans Temp gauges,Rancho 9000's set at '1',Diamond Plated Tool Box, OEM U. R. Bedliner + other stuff.
Fact:The First Fords' had 'DODGE' Engines! The new PSD's need them!
Robby,
Thanks for your reply. Do you need the 4. 10s
for towing? I know I may not like the solo top end but I can deal with that as long as I can haul the 5er easier. I'd like to hear about some of your driving experiences with the 4. 10s.
Thanks again!
[This message has been edited by Tagalong (edited 03-28-2001). ]
I had a 2000 with 3:54s. I kept it 7 months and sold it. Ordered my 2001 with 4:10s. Awesome!
2001 2500 QC, ETH/DEE,4:10s, LSD, EZ with elbow(26. 5PSI)Stage 1 injectors from Carl, Boost/Pyro Guages, 4" Turbo back, BD Brake,Mag-Hytec Cover, Kleen Wheels, Energy Release, 70 gal. fuel, 20K Reese. 31,000 Miles on 03/01/01(Auto/Truck/RV Dealer)
Have had 2001 4x4 w/4. 10s for 21,000 miles. Tow a lot, so love the gears.
Didn't like the high rpms while running empty, so added a Gear Vendors.
Ran about 2450 rpms w/4. 10 in 5th at 75mph.
Engine noise at 90mph was scary!
Runs about 1900 rpms w/4. 10 in 5th GV OD at 75mph.
Now all is good.
Pulling 5th wheel tt on 2200 mile trip soon. Will know how well I like the GV unit when I get back.
Thanks gentlemen! That's what I hope to hear.
I just returned from the dealership and yup,
rpm is higher, and gas milage on the overhead will take some getting used to. I hope the engine still has some breakin to go (4900 miles). I stay pretty much to the speed limit especially with the 5er so I hope to manage lower rpms for most driving. Now we're getting itchy to get out and tow! The only problem now is that the snow is keeping me from getting to hitch the rig up! #ad
holy toledo!!!!you have A LONG WAY TO GO before broken-in... towing your 5'er will hasten it,but i'm sure you'll see an improvement in due time... good luck!!... tom
2001QC 2500HD LB ETH/DEE 4x4 4:10's LSD, Pacbrake,Combo Gauge on A pillar,All options except cab lights,Xcelerator air filter,Forest Green/Light driftwood. Westin tubular black powder-coated side bars.
26'Holiday Rambler 5th wheel. Extra Class Amateur Radio Operator ke3Rx
I really like the 4:10s. When towing on two lane/55 MPH roads I am still at 1700. Any higher gear and I would feel uncomfortable. Also, my fuel mileage is great when I run the speed limit.
2001 HO 6 spd 2500, 4. 10 LSD, Towing Package, Electric Brakes, SPA EGT/Boost Gauges, Fog Lights, Real Backup Lights, Molded Running Boards
Thanks for the support Tom and Alan.
That's just the information I was hoping to hear. In reality, I wasn't sure I was making the right move, if I found out I didn't like the gear change the Missus was getting ready to (literally) "bomb" the Ram! #ad
Dave
White 2001, 3500, Auto, (now)4:10,QC,2WD,LB, (soon to be) transmission and EGT gauges,34' DBL slide Cardinal 5er
On my stump: For a decade now Dodge has stubbornly hung on to two ratios. The 354/55 and the 410s. But they have made a number of changes. 1. Moved from a lower rpm engine(12V) to a higher rpm engine(24V). 2. Moved 2 sizes bigger on tires on both the DRW and SRW trucks. I will be the first to admit my 4:10s and DEE are ideal for towing. And I will also be the first to admit that they are a little tight for bob-tailing a 1,000 miles at 75 mph. Best all around needs to be 373 or 390. Ford gives a much wider choice of ratios as well as GM. My hope is the "New Generation" trux will come with a wider choice. Does anyone know how to email the design eng. section of DC?
Does anyone know if 3. 73 gears are available from aftemarket gear vendors? If you're going to pay for a gear change, wouldn't it makes sense to put in 3. 73?
Just wondering. .
Charles
2000 QC 2500 4x4 LWB ETC 6 Speed Anti-Spin 3. 54 Trailer Tow 241HD, DD1's, Practical Solutions Boost module
yes i believe that 3. 73 is an available ratio .
tagalong , i hope they changed the wheel speed factor in your computer , i would double check that as your speedo will be off .
Not to worry about the speedo. The sending unit reads from the ring gear. As long as the stock size tires are used, different ratios won't change the speedo. On pre-'98 models, where the speedo reads from the tailshaft on the transmission, a new sending unit gear is changed to correct the speedo.
98 2500 CC SB 4X2 12v 5spd 4. 10, -silencer, AFC+20, Edelbrock IAS, VDO gauges, Reese 15k Classic
97 Dodge Stratus 150HP
92 Harley Fatboy, Dynojet fuel management, Supertrapp 2-1
00 Jayco 25' 5th wheel, single slide
where did you find info stating that the speed is taken off the ring gear ? mt trans has a speed sensor in it , what is that used for ?
[This message has been edited by Mopar-muscle (edited 03-29-2001). ]
The sensor on the rear axle is the sensor for the RWAL antilock brakes.
98 Properly Valved 4x4 SWB QC ISB A/T Metallic Red w/ tan cloth interior, DC nerf bars, DC two piece mud-flaps, 275 h. p. injectors, Monroe Gas Magnums, Armor Tuff spray in bed liner, Goodyear Wrangler ATS 285/75r/16, BD Heavy Duty Valve body. Walker 21468 thru flow muffler,Cobra 29 NWST CB. American Racing Wheels. Power Edge EZ control module,Tuff Country 2" Leveling System, Draw-Tite Front Mount Receiver.
When I went to 32" tires on my '95, I had to change out the gear in the sending unit on the transmission's tail shaft. When I went to do the same on my '98, I was told and shown that there is no sending unit on the 98 and later transmission. The speedo shares the ring gear sending unit with antilock brakes. Changing tire size requires changing a parameter in the pcm to correct the speedo as it changes axle speed for a given mph. Changing gear ratio doesn't change axle speed for the same mph and doesn't alter speedo accuracy. Unless Dodge has gone back to a sending unit on the transmission, which would be a good thing, I don't know what the sending unit is for. Mine has a plug in the hole where the unit used to be in previous years.
I wouldn't have one without the 4. 10s. I drove a 2000 the other day with the 3. 54 and it had no "balls" on takeoff compared to mine. If you plan on towing anything even semi-heavy, the 4. 10s are the only way to go. I'm getting 17-18 mpg unloaded on the highway running 65-70 and 10-13 mpg towing 12k# at the same speeds! I don't think you can ask for more than that from a big heavy truck!
Will
'98 3500 24v, auto, 4. 10s, Poweredge EZ, K&N, Gauges
38' United Expressline
X-treme Gooseneck race car hauler.
Other Bad Habit:
'87 Buick Regal
Turbo V-6 1400hp, 1200ft/lbs
4. 99 @ 142MPH 1/8 mile
7. 70 @ 179MPH 1/4 mile
And lookin' for more!
SO I'M A TURBO MAN... .
BOOST ON!
I am looking for a complete rear axle with 4:10s I pull Travel Trailers and 5th wheels new ones to dealers I have 3:55 now and its a 4X4. The Junkyards are telling me 2000 or 2001 only Im only going to change the rear for now I know I wont be able to use 4X4 but Im not sure that I will keep doing this so only the rear for now. What will fit my truck? The 3:55s are workin for now but the trans isnt going to last long like this too many downshifts too fast for 3rd too slow for OD.
2001 2500 4X4 QC SLT LWB Auto Ordered 3/16/2000 delivered to the dealer 5:30 pm CST on 5/9/2000
To FJ40Charles: Yes the R&P sets are available for the 3:54 rear ends to change to 3:73 or 3:90. The set slides right into the existing carrier. The cost is $350 for the set and can be ordered from a co. in the northwest. Check some past threads on this subject. This is not the first or the last time we will bat this around. The name of the co. is some guy's name and something else. ie: Dave's or Randy's or Joe's Gear service. It's something like that. My memory is excellant, it's just short.
Barry,
Thanks for the info. I've heard of Randy's ring and pinion, but not the others. I should have done a search first.
Charles
2000 QC 2500 4x4 LWB ETC 6 Speed Anti-Spin 3. 54 Trailer Tow, DD1's, Practical Solutions boost module
1969 Toyota FJ40
350 TBI, Turbo 400, ARB lockers front/rear, 4 wheel power disk brakes, 4. 88 ring/pinion, 3 speed transfer case, full roll cage, Warn 8274, MRT 36 bolt beadlocks with Super Swamper Boggers (16x35x15), Saginaw Power steering, custom bumpers/fenders/nerf bars. Conquered Tellico and going to Moab this May. Loves to be pulled behind the Dodge and pass the powerjokes going up hills.
