I'm Installing a new fan clutch 2004 check it out
Vibration at highway speeds
48re trans rebuild having issues
Yo Hoot
Somehow the lower shroud came loose.. fell part way down and the fan cut the CAT5 LOL cable. Got 185,500 on the truck but only 10k on a rebuilt 5.9 cause a valve guide dropped. I paid a shop to pull the motor... sent it out for rebuild and same shop re-installed it. I think there were a few loose ends but overall truck has been great. I think they didn't install those plastic Christmas tree push pins that retain the lower shroud.
Anyway did a lot of research on methodology. All I did was put a file against the fan pulley between the bolts to lock it and bought the 36mm flat wrench. Stuck the file there and hit the wrench counterclockwise a few times and she came loose. Pulled it out from below so I didn't need to mess with removing the upper shroud.
