I've made some improvements to the original fuel tank vent kit. The kit now relocates the vent from the lower part of the tank to the raised part of the tank with a new 3/4" vent line. The stock vent line is capped off. This eliminates the "T" fitting and makes installation a little easier. The new kit vents as well as the old kit or maybe a little better. It seems like it takes 10-15 seconds less to fill the tank so you can see fuel in the neck.
The parts in the kit are resistant to diesel fuel at a wide range of temps. This proved to be the hardest part of redesigning the kit as most materials that simple bulkhead fittings are made of are not resistant to diesel fuel. Some are, but only to temps 72 degrees F and below. I consulted multiple chemical resistance charts to make sure that everything would work with diesel fuel. You can see pics of the new install in my reader's rigs pics.
