Forrest Nearing said:
just to reitterate what has been stated before in this thread (I'm sure, I haven't read the whole thing)
inducer size doesn't mean much... it obviously means something, but you could have a 62mm wheel outflow a 66mm wheel... doesn't mean the surge line or pressure ratios would be right, but it could flow as much or more...
there's so much more to compressor wheel design than major and inducer diameter it makes my head spin
True. A more aggressive blade angle will make a given diameter flow more.
But assuming identical compressor designs, the bigger inducer's gonna grab a lot more air with each revolution.
There's not going to be *that* much difference in blade design because you still have the same surge and PR requirements because it's going on the same engine. A smallish, low RPM engine needs higher PRs to get the air into the engine, which only magnifies the problem.
The B1s were known for flowing a lot of air for the smallish compressor. The newer BW wheels can be even more aggressive.
Years ago a "full B1" was a laggy, barely streetable turbo that would still get toasty at 500+hp. Now we have a SPS62 that flows more, cools better, and spools better (or so it would seem).
Methinks the B1 is now a relic of "back in the day". Once upon a time, people were actually running H2Es as singles. How many hybrid H2Es are out there now? They're old tech.
These new singles are giving twins a run for the money when paired with nitrous. Maybe not for towing or sustained HP, for a short blast-- the single on spray looks pretty appealing.
jmo
