Ok, I want to know ..... when an ad for an injector says it gains 100 Hp ( example ) , Is that the HP that is going to the ground or is that a flywheel estimate. I have seen a lot of adds for injectors and have narrowed it down, but want to find out from the membership what they believe to be true, preferably by dyno results.
Example, I have a set of baseline dyno numbers from a stock configuration and dyno numbers from other mods I have tried , to see what an item actually gained. EX. I put on an Edge EZ and its advertised HP (65) and TQ ( 185 ) gains were this: I gained 38 HP and almost 200 TQ. Now I am not complaining but I didn't get the full HP to the ground as I thought.
Using the above for an example, if I install , lets say 80 HP injectors, will I actually get that on the ground or will it be considerably less than that?
The injectors I am looking at are the F1 Mach series, or the Bullydog injectors.
Thanks
Thanks
