Archived injector problems
Archived Gasoline in Tank
Archived 01 with questionable ECM problems?
Just replaced an injector in my 05 and now when you shut it off it coughs or diesels? like it dont want to stop. Cant figure what would be doing it and not sure I should drive it and being my only vehicle I kinda stuck. Any suggestions? thanks
Pull the wiring connector for that injector, run it, and see if it still diesels after shutdown. If not that injector, maybe you lost another. Why did you change 1 injector to begin with? Sets are the more recommended option. How many miles?
-j
I only changed one because I am about broke as it is and that was the only one bad. I dont think another one went it was running good, better than ever really, and all the exhaust ports were running about the same temperature. I'll check though.
