Engine/Transmission (1998.5 - 2002) Injector pump replacement
Just a final follow-up to the Edge Juice w/Attitude question, here is what I learned. I spoke with Edge "Tech Support" and they indicated that if you only use power levels 1, 2, and 3, you don't need to connect the wire to the injector pump. The connection is only required if you use power levels 4 and 5. Since I have never gone beyond power level 3 in towing my 5'er, I'm not going to reconnect it thus my OEM warranty from Dodge should remain good for the duration of the warranty period.
So far truck is running great, starts good in cold weather with short spin of starter. Back on the road again.
