rbattelle
While I believe/know from everything I've read over the past few years that rbattelle's info is correct then these are actually two different issues. How so? Well the injector failures on OEM injectors are primarily caused by insufficient filtration while the failures that are pressure related are caused primarily by pressure spikes. If you're running a pressure box then you have to have the common sense, given the pressure spike information supplied above, to NOT run your pressure turned up all the time. An occasional turn up/dial up of power is not as apt to damage your sticks. It just makes sense that anything that is run at the max is more likely to achieve failure.
I think that's a prudent way of looking at it.
Ryan
