Bob Wagner
new sticks are scheduled to ship this week
DwayneKelch said:BPINE - we all could use a few friends like you... what a pal. Be careful not to get sucked into the air filter when Dave starts to build boost. Remember to wear your fall harness when attempting work like this. You can clip onto the lifting eye on the front of the engine.![]()
DLBurns - it's not really the horsepower that kills the auto trannys, it's the torque. The components, unless beefed up, can't take the torque developed by the mighty Cummins. Your horsepower went up 85, but the torque went up about 160lb/ft. Add the hp/tq from the EZ and you've significantly increased stress to the transmission over stock. I'm no transmission expert, however there are many on this site that could tell you whether the upgrade to your transmission will hold the power, torque, and towing weight (12K pounds) you're throwing at it. Call Suncoast to get their input on your setup.
Hope you get the two problems worked out.
Dwayne
Bob Wagner said:new sticks are scheduled to ship this week
DLBurns said:Moved the EZ jumper to level 1 on Tuesday, went for a short run and am seeing considerably less smoke.
I'll have to take it out on the Performance Diesel test track ( Hwy 85 ) and see what the EGT's are now!
We also tested the pyro and found the Isspro to be reading about 150° higher than a new Hewitt gauge??
I emailed Isspro about the problem and have not heard back from them!
still![]()
JBlock said:If your Isopro is the one with an amp. there a 1/4 turn adjustment to correct the high reading.
DLBurns said:Thanks... ... I don't think Blair will fit under the dash to adjust the pyro sender while I am driving 90 down the Performance Diesel test track
Looks like I am gonna have to wait until I can get it on a dyno #@$%!
BPINE said:I might fit but don't ask !!!!!![]()
If it wasn't so much trouble I would say send it back to Ispro and have it calibrated, we need to think about this in the meantime drive it like you stole it.
DLBurns said:We also tested the pyro and found the Isspro to be reading about 150° higher than a new Hewitt gauge??
still![]()
DLBurns said:I have lots of power, recently dynoed at 340Hp and 780 Ft/lbs torque. I just can't use any of it because of the freakin high egt's.
Dave
