Injectors+box+stock clutch?
Jim Leonard
FREE Train Horn
I currently have the 275RV injectors in a 98. 5 2500 4x4 with 3. 54 gears and 285 BFG tires. I'd like to add a PE EZ box, but would like to first see how many people are successful with the stock clutch not slipping. Replacing the clutch isn't in my budget for this year.
you should be ok, from what I hear the 5spd clutches are stronger than the 6spd clutch that I have... . she will not take my current BOMBs. I am over here in Hillsboro, I would love to see your truck.
pgr 503-204-7222
-Cliff
2001 ETH-DEE, Diablo Power Puck, Bosch 275's, Practical Solutions Boost Module and Elbow, LFT Silencer Ring Eliminator, K&N, Straight Piped http://www.mudrunner.sites.cc
I have stage II injectors -Psychotty- Edge EZ- 6Sp. (285 HP /558Ft. Lb Trq. at the rear wheels) and tow a 13k trailer with a stock clutch. I have had NO clutch slippage or EGT problems with these mods. regardless of % grade or speed. I think that the secret is to get into the power slowly. I avoid hammering the throttle or doing burnout starts. So far so good!
2000 Qc LWB ETC 6Sp 3:54 LSD, + all the options except leather, BD Stage ll Injectors,Edge EZ, Psychotty& K&N,
BD E-Brake with Shifter Control, ISSPRO EGT and Boost Gauges, Transfer Flow 50 Gal. Alum. Fuel Tank, Line X
16K Hijacker Double Rocker, Pulling a 35Ft. triple slide Spinnaker 5vr.
1996 Viper GTS
Suzuki DRZ400
1100 Yamaha Cruiser
well we thought stock clutch would hold, its only slipped a couple of times, but I think the clutch got hot and its warped... ... ... . its hard to go into gear now so the new mcleod is on its way
Brandon... ... ... ... ... ...
Danelle's Dodge
Yeah,you ought to be just fine. Eventually with alot of abuse it will start slipping a bit,but you can keep driving it a long time even if it does.
-Mike
Brandon, that may depend on if you tow anything, and heat up the clutch. An EZ and 275's are a great combination.
Fred Swanson
Co-Owner
Canyon State Components, LLC
www.canyonstatecomponents.com
'00 QC,SB,4x4,Auto,3. 54 w/LSD,Trailer Package,Tow Package,DTT's
TC(91%)&VB(80psi),DD2's,EZ,HOT PE,K&N RE-0880,Cummins RED Valve Cover
