Intake Horn
Blue smoke need help
shifter
Which aftermarket intake horn with grid heater delete do you recommend?
I just installed a Banks monster intake and am happy with it…. there are h8ters that say it’s a waste of money etc.. I see it as a way to address the carbonized heater grid, heater bolt, better unrestricted airflow, etc
Mark Hood
Mark Hood
How much was it? They make quality products that sometimes can be equaled for less $$$.
Spoke to the service Manager at local Dealer and asked him what he thought about the grid heater nut falling off. He then proceeded to tell me how he replaced his engine in his 15 DRW because of the nut failure.
I am out of warranty at near 100k so it's time to do something about this potential time bomb.
I got the unfinished one for 850. I was lucky and got the “spin the wheel “ discount of 10%
Mark
Mark Hood
What year is your truck? My son swears by them, Banks. The pictures of them seem impressive, oem v/s Banks.
I just installed Banks Monster Ram and very high quality product. Does it make a difference? Absolutely…..seems to be reduced lag time on turbo spool…..Just bought the Banks Boost Tubes and expecting same high quality product from Banks…..
Who did you buy yours from?
I bought mine from Banks online….I am retired US Navy Master Chief and get 10% from Banks so I went with them. Shipped in great packaging and installation video was huge help….along with my son-in-law!
Also….just bought the hot and cold boost tubes from Banks online. Once installed I will get IDash Super Gage and see if I need a pedal monster
I can’t speak for the 4th Gen intake horn but I can speak for Banks products. They do their homework. Their parts fit they work as advertised. I installed their intercooler kit on my 89. I installed the intake horn on my 05. The intake horn on my 05 made a huge difference. Best way to describe it is the engine felt like it wasn’t held back after it was installed. I’m betting the new design for the 4th Gen will allow the engine to breathe even better.
What everyone seems to overlook here is, the more air volume you have inside the intake system between Turbo and intake Valves the more delay you have from pushing the throttle to "move on".
Cummins designed the intake that way to serve the air need for the 325/600.
If someone pushes way more, sure go for that Monster, but in a stocker I see no benefit from doing so.
Yep.... might see some benefit if your hot rodding around or pulling a sled, but I simply cant see the benefit on a stock truck doing its purpose built job.. If I was worried about the grid heater, Id just remove it and put it back together without... 3 trucks now and never needed the shiny stuff, bigger intercoolers, etc..., intake system on my 04, 12, and 20 seem fine for doing their job and my 04 was not stock fueling.
I am by no means judging those who choose to add the accessories, just saying a wise man once told me "Chrome don't get you Home". .JM2C, best of luck.
On my o5 the best way to describe the effect the intake horn had … the engine always felt like it was being held back at higher RPM’s. Torque/ power would fall off. After I installed the intake that “perception “ was noticeably less. Turbo lag was about the same, but at higher RPM’s the acceleration didn’t just fall right off. As it did with the stock intake. On the Gen 4 trucks the intake is much larger. I really doubt you will see any changes. The 3rd gen has a very pinched down intake.
I can say since having to replace the turbo actuator on mine, the City Diesel replacement has me relearning to drive my truck! Much smoother and quicker response on the throttle! Turbo lag appears less as boost numbers build quicker. Just throwing that out there as the engine doesn't need any help with making power. Had thought about the throttle sensitivity booster, not now! But you know it's your truck, your money. Just enjoying them how you like.
So my 18 dually is going out of warranty this year with 31k on the clock. I need more info on this nut that needs to be replaced. Thanks
So I did find a thread on this. How can I do a disconnect of the grid heater with out throwing a code?
I saw Banks makes a replacement that gets rid of the problem but maintains the heater function
They do. The heater isn’t as powerful, but seems to work ok in cold climates.
Lots of complaints about the installation and instructions.
