First a BIG "Thanks"
to TDR Members "muchsnow" & "TFabian" for their timely contributions on the " My steering sucks" thread. The research and parts #'s posted made it easy to acquire the correct conversion parts. TFabian for the email with needed tools, including hints and tips on the dreaded ball joint replacement.
I think a combination of these items not just a single one is the cure. The Inverted "T" Conversion is a first fix if you have the "Y". Followed with the DSS and 03 track bar.
The truck really steers as new or better!! Oo.
I will install the steering damper when I find a cool clamp. Drives great without one. Ideas And help on this next step needed.
Bruce in Virginia
A recap of my vehicles symptoms.
1. Excessive front tire wear on insides
2. Wandering steering- 1/2 lane changes!
3. Pulled to the right
My own symptoms
1. Scary towing
2. White knuckle fatigue
3. Disbelief, just installed DTT transmission,
4" SS exhast,Exhaust brake
4. More $$$$ out of pocket
Local front end shop diagnoses.
1. Worn lower ball joints
2. Worn L & R tie rod ends
3. Worn steering gear box
The cure.
1. TDR links for "Best" non-OEM items
2. One patient & understanding wife that
trusts TDR logic.
3. While torn down - replace it!
4. A Bigger Hammer
Replacement parts list:
03 Track Bar Bracket & 03 Track Bar $400
Dodge Steering Stabilizer$189
http://www.sourceautomotive. biz/
PSC Steering gear box $290
http://www.offroadsteering.com/
2- 5015282-AA Hub Brake 50005006 2@$345=$690
1- 5086532-AA PS Hose 19058007 $73. 75
1-52006724-AC PS Hose 190058007 $15. 00
Leesburg Chrysler/ Dodge
2- Brembo replacement rotors 2@$66=$132
1- Ebc 6000 series truck pads $54
http://www.tirerack.com
4- ED3344 Edelbrock Performer IAS Shocks $277
ESHOCKS. COMESHOCKS. COM
2- 5-806 Spicer front u-joints 2@$55=$110
2- 44-2496 adjustable upper ball joints 2@$132=$266
2- Moog lower ball joints 2@$93=$186
1- DR3520 rear timbren set $196
Alignment including caster adjustment $65
Chantilly Frame and Spring
Inverted "T" Conversion for 01 3500 4x4
1-TRW DS1459 Front Draglink $29. 28
1-TRW ES3496 Front Tie Rod End $29. 28
1-TRW DS1456 Front Draglink $94. 88
1- TRW ES3498S Front End Sleeve $25. 28
1- TRW ES2012S Front Tie Rod End $19. 33
1- TRW ES3527 Front Tie Rod End $22. 48
Advanced Auto Parts
Advil, Bandages
CVS Drugs #@$%!
__________________________________________________________
2001 3500 4x4 AT White/ Gray leather & all factory options except tow mirrors.
65xxx mi. DTT Transmission, Banks exhaust brake & 4" SS exhaust, Airaid intake, DSS & 03 Track Bar, PSC gear box, Edelbrock shocks, Pop-Up gooseneck ball hitch.
Bruce in Virginia
My own symptoms
1. Scary towing
The cure.
trusts TDR logic.
4. A Bigger Hammer
Advanced Auto Parts
Advil, Bandages
CVS Drugs #@$%!
