nps said:Getting to the ECM plug should be easy enough - just pop the fuel filter out of the way. Two bolts and it's dangling free and out of the way.
Actually, with my Jake I got tired of the ECM turning it on when I didn't want it to. So I put a switch on the shifter and wired it to a switched 12V source off the fuse box. The ECM/factory switch is still wired in, but I never use it. If I were to do it all over again I would have just skipped messing with the ECM wire altogether.
Assuming that you're referring to the ISB Ram in your signature, exactly how did you envision the brake engaging "under throttle"? The ECM controlled exhaust brakes on the 24-valve Rams depend +12 volts at pin #20 of the ECM. The +12 volts is only present when the engine has been in a defueled condition (not "under throttle") for about 1. 5 to 2 seconds or longer.WestTN said:I did not want mine to be able to engage under throttle...
Possibly - but after reading the original question about removing the starter motor, followed by two replies that basically said leave the starter motor alone and work from the top, I am still wondering what method is described by I did mine myself. Just crawl under there and do it. Less work that way. I did not want mine to be able to engage under throttle, as that might cause problems.EricBu12 said:Thomas,
he was refering to not using the wire pin in the ECM and just hooking a switch to it... .
Click here , then click Dialectize to read a translation. Maybe it will be clearer then. :-lafThomas said:Possibly - but after reading the original question about removing the starter motor, followed by two replies that basically said leave the starter motor alone and work from the top, I am still wondering what method is described by I did mine myself. Just crawl under there and do it. Less work that way. I did not want mine to be able to engage under throttle, as that might cause problems.
