Jeeps..whos got what
2008 Dodge Charger
Viper production run ends in 2011?
'98 XJ 4dr 4. 0L AW-4.
D-44's front and rear, full spools, 4. 88's, discs at all 4 corners, 33" trxus MT's. 5" lift, trimmed fenders, homemade bumpers, 9,000lb winch, no carpet, falling headliner, and a fair bit of body damage from a flop in Tellico at XJ-Crawl in July of last year.
'99 XJ 4bngr 5 spd 2dr 2WD daily driver. Floor mats, and a crappy CD player.
'93 YJ
2. 5 Liter VM Turbo Diesel, AX-15 trans
4 1/2 inch lift, 31's
installing 4:10's and detroits right now as a matter of fact.
milemarker hydraulic winch
homemade bumpers
2 low kit and slip yoke eliminator
Currently, 75 CJ5 (rust holding hands, but a fun beater).
91 XJ. Nothing special, but it works.
Wagoneer/M715/choptop thing.
Past, 74 CJ5 with LOTS of goodies!
67 M715
83 FSJ Cherokee Chief widetrack.
Anybody know of a link to a detailed full swap of a 4 bt into a Wrangler and all of the parts/fabrication involved? Want to swap a cummins into a TJ or maybe the YJ.
Here is a picture me and my buddy in his Cherokee at carlisle 06
<a href="http://imageshack.us">#ad
</a>
</a>
</a>
I know, its not a jeep, its actually a "gulp" Ford. But to the uneducated, it looks like a willys. Everyone I see always say "nice jeep" Then I have to explain its a Ford and how they had part of the military contract during Vietnam, yadda yadda. Thats when you can hear the crickets start:-laf But it will go everywhere, hopefully Colorado this fall. Oh yeah, the IFS and IRS work quit well actually:p
https://www.turbodieselregister.com/forums/showthread.php?t=169262&page=5 Post 67 to make it easier...
I forgot to mention the best part though, I got it for free!Oo.
1995 - Goin' up for sale too!
Hi All!
I have a 1995 (last year of the actual leaf springs on all four corners) Jeep.
It's a Wrangler w/ Sahara package, Hard Top, American Alloy wheels, 30 x 9. 50 x 15 BFG TA KOs, full size spare (same wheel/tire as the 4 corners), 4. 0L, A/C (needs condenser), Kenwood Stereo, Auto transmission (I know I know... bummer!)...
BUT - for a 1995 it is CLEAN! Looked underneath before I purchased it and there must be 3/8" of ZieBart under the whole truck! Only rust is on the door pins and hinges! I have owned it for about 3. 5 years - only selling due to not needing a 3rd vehicle now.
So - Keep your eyes open in the classifieds for this one...
Will post pics soon!
2001 TJ, just turned over 100k miles. 4. 0L, 5-speed, 4-inch Teraflex long arm lift, Warn XD9000 winch, Wilderness bumpers, 33" Goodyear MT/R's, etc, etc,
'05 Liberty CRD. It is the only one I could find with a properly fueled engine! I wish the 2. 8L in the Liberty was offered in a Wrangler DOMESTICLY, with a 5-speed!
Just a ratty 80 CJ7 6 with a 4 speed. Main use short trips so I don’t have to fire up the diesel. And of course a little fire road action here in Big Bear.
Titled as a 1948 Willy's CJ-2A, but has an original M38 tub, civilian hood and tailgate and fiberglass aftermarket fenders on a CJ-2A frame.
Rear Axle: 1970 CJ Dana 44 rear axle with an ARB air locker, 4. 56 gears and warn full floating axle kit using premium manual hubs.
Front Axle: 1978 CJ Dana 30 front axle with an ARRB air locker, 4. 56 gears, big disc brakes, and 297 jointed warn axles with warn premium hubs and hub fuses.
Engine: A Buick odd-fire V6 with HEI conversion. The motor was with the jeep when I bought it, runs good and doesn't burn oil. The number on the block shows it to be a later 231 CID odd fire from 1977, not the earlier 225.
Transmission: SM465 4 speed transmission with granny low, rebuilt by Herm the overdrive guy with a brand new mainshaft conversion to mate it to a dana 18 transfer case. The clutch is a Centerforce dual friction from advance adapters and it uses the old heavy jeep flywheel. Clutch actuation is from an advance adapters chain linkage conversion.
Transfer Case: Dana 18 with a 1 1/8" Novak shaft. A disc emergency brake rides on the transfer case in front of Tom woods long travel, straight spline driveshafts with 1310 u-joints, where the old drum used to be. Tom Woods supplied the emergency brake kit as well. There is an advance adapters Saturn overdrive mounted to the transfer case too.
Brakes: 67-71 style dual pot master cylinder in factory location, for separate systems front and rear. The rear brakes are stock 10X2 drums from the 70 CJ rear and the front disc's are stock from the 78 CJ rear.
Steering: Power steering conversion using a Saginaw 800 steering box and pump from a 1967 camaro. A factory jeep waggoneer frame mount and parts from an advance adapters kit allow the steering to use factory length jeep CJ tie rods and also allowed me to keep the round factory radiator crossmember. The angle of the column was shifted up slightly to give a little more knee room in the process, and a flange was welded on to the bottom of the column to mount and hold the lower bushing.
Misc: Onboard air compressor for the ARB's, along with a tire inflation kit. All autometer gages in the dash, including a digital speedometer for easy tire size calibration. An optima battery and late style spade fuse box and wiring harness from painless wiring. 4 Plus offroad shackle reversal kit with 2" lifted wrangler springs from BDS. BDS shocks, Bestop Tigertop and marine wiper motors. The PVC on the dash is a defrost duct which attaches to a vintage air heater/defroster/fan unit. It's enough heat to allow comfort with a soft top below 30 degrees.
Tires and Wheels: American racing rims and super swamper TSL radials 33 X 10. 50-15.
Heres my 97' TJ2500. 4. 0, ax-15, D44/D60 35x14. 5x15 boggers, welded rear, 8" skycracker springs/double flex links, 6" stacks... .....
'93 YJ
homemade bumpers
Where did you find that? WOW! That is what I wanted to find before getting my Liberty. I want a MANUAL transmission, diesel powered Jeep!!!
