If you look at this procedure and it makes you uneasy or uncomfortable, find a coach or someone else to do it. A good wrench on gas engines should have no problem if he has a Dodge Shop Manual or equivilent.
It took me 4 1/2 hours to do mine, but I had never been inside of a 5. 9 CTD before. I could probably do the next one in 2 hours.
Personally, I prefer to tap the dowel pin back in, raise a burr in the bore of hole with a gouge punch (or a prick punch could be used) in three locations surrounding the dowel pin, clean the bore
with brake Kleen and air, and loctite the pin in with blue loctite for good measure. This is not a tdr approved solution, but one I prefer.
None of my bolts under the front cover had loosened up more than 1/8th of a turn, so I just retorqued them. If you have a good place to work, its probably safer to loctite them too.
Buy a front crankshaft seal and plastic installation sleeve from Cummins. To install the seal in the front cover before replacing the front cover on the engine, support the bore of the seal in the front cover with a large socket or piece of pipe just slightly larger than the front seal O. D. when you want to drive the seal into the front cover. It will bounce a lot if you don't. I didn't have the nerve to put the front cover back on the motor, then try to drive the seal in as the instructions read.
If you don't have the right size wrench and fan pulley holder, you can fabricate them easily with 1/4" steel sheet, a cutting torch, and a 4 1/2" grinder. If you are in a hurry, use a 2# hammer, a round rocker prybar or large chiesel to break the fan nut loose and tighten it back up when done. Pull the fan and shroud out.
Find a large flat piece of cardboard to set up against the radiator
to protect it in case you slip or drop a tool.
It takes longer to torque all the bolts down that you can get to than it does to fix the dowel pin.
Mel
