Template errors
  • Template :: [E_USER_WARNING] Method canViewRmsItems is not callable on the given object (SV\AdvancedBbCodesPack\XF\Entity\User) (src/XF/Template/Templater.php:1277)
Competition Keating 1 Comp 1
Off Roading carli suspension 3.5" kit
JasonCzerak said:
If your going to build up a CR for drag racing, why is it 4 door?
Because they had the truck, meaning they didn't have to go buy one. Not bad for just some bolt on parts. I think Greg put one of his cams in but other than that it just bolt on stuff.
Scary part is he make a little more power than I do with a built motor. I run a SPS 66 he has a Silver Bullet. He'll never make a grand to the tire and I know mine will.
Jim
4 door to racing = short bed to a real work truck :)
So who's going to be the first to make a CR make lots of power in a truck that's 5500# 2wd with with a nice suspension?
Also, doesn't "nhra" rules dictate that they'll need a roll cage in that truck now that it's in the 11's? I can't see one.
They had the truck.
Its an 03 with 210,000 miles on it.
Stock Short Block
Ported Head
ZZ Manifold
Hogue Cam
Industrial Injection
Stage 2 CP3
3 Flow Injectors
Silver Bullet (66mm)
Nitrous Express 2 Stage Progressive (only using one stage right now)
NADP Full Billet Transmission
AFE Stage 2 Pro-Guard 7
MBRP 5" Exhaust
ATS Exhaust Manifold
Cal-Tracs
And of course a little Tuning
I think that's about it. I may be forgetting something. But, I'm pretty sure that's all that was used in that particular run.
Later,
Wes
11. 50 is the cut off now.
JasonCzerak said:
... Also, doesn't "nhra" rules dictate that they'll need a roll cage in that truck now that it's in the 11's? I can't see one.
According to the 2004 NHRA rule book, a roll bar is required in vehicles running 10-11. 99, (-13. 99 for convertibles). A roll cage is required for vehicles running quicker than 11 if the vehicle exceeds 135 MPH or if the vehicle from the firewall rearward has been altered from OEM as-manufactured condition (wheel-tubs are allowed). These rules may have changed in the past couple years.
Greg is running in a 12 second class. You can run up to 2 tenths faster than your dial, so a 12. 20 + an 11. 80 = 12. 00 as I understand it...
crawler said:
They had the truck.
Stock Short Block
Ported Head
ZZ Manifold
Hogue Cam
Stage 2 CP3
3 Flow Injectors
MBRP 5" Exhaust
Cal-Tracs
You forgot the Rev Gain :eek:
Jim Fulmer said:
I know were he is, he's having allot of fun right now doing something totally different..... but I am in the know!
Jim
Translation: The rumors are true, he lost his Dr. P ride, and his fooling around in a street truck, where he should have started!
He's starting out the day qualified #2! Ah how nice it would be to have a truck that would run a 11. 76 with no smoke. That #2 only number just flat floors me.
Jim
2004 Neal???!!! Get with the times brother!!! :rolleyes:
Those silly 3rd Gens :-laf
Come on over Jim, the water's fine. :D
