I have a '97 4x4 with an auto, as well as TST plate, gov spring kit, 270 injectors, 16cm housing & AFC spring kit.
I had a DTT VB & TC installed, and I love it, but I keep blowing the resistor in the VB. It lasts for a day or two, then dies. After that, I only get second gear starts.
The shop has replaced the resistor several times, and has put a stock VB back in, and gets the same results.
One odd thing: when the truck is cold, if it's fored up and instantly put into gear, the engine runs rouhly and surges a bit. When that happens, you get 1st gear starts, untill you shut off the ignition. If you start it and wait more than just a few seconds, it runs fine and gets 2nd gear starts. This is according to the trans shop.
Any thoughts?
Thanks,
Tackett
Any thoughts?
Thanks,
Tackett
