I have an automatic (i. e computer controlled) charger I bought at Sam's Club a few years back that does the charging. It will regulate the charge from 25 amps down to near 1 amp, then tell me I have a full charge as it shuts off. Batteries load test fine and are matching group 27, only about 3 months old. They seem to charge to ~12. 68 volts each when I checked earlier this afternoon, near 85+ degrees. I have left the PDC disconnected for 2 weeks prior and the batteries held the charge and cranked the CTD over fine. So I feel confident my batteries are OK.
I have disconnected the any accessories I have added that were not connected to the Accessory Key circuit. I have verified there is no draw from my add ons like the brake controller, exhaust pyro, boost, transmission temp gauge and fuel pressure gauges. I have even checked that the CB and radar detector are completely off with no current draw.
I have used many suggestions and removed the under hood lamp, not just the blown bulb, completely disconnected the glove box switch/lamp.
I have tried the seatbelt issues found in the older archives of the TDR, but I have manual belts in the regular cab. I think the Quad cab belts must be very different in the 99's. So I think I can rule that one out.
I need to get a new connector for my digital amp meter, as I have broke it so I can not make any readings now. So with that being said, I recharged the system till my charger shut off indicating completely charged and simply walked away. I will let it sit till tomorrow afternoon when I can have a little time to test other ideas.
I really want to thank all who have taken time to make some really good suggestions.
Drue
Drue
