Kwikspool b1b-2 to b1-2 tow
What next
12cm2 turbo housing improvements how-to
Here's the deal,i bought a kwikspool b1b-2 on a recommendation from a local diesel shop,had it installed with my BD brake. Due to a busy work schedule,i could not tow with it until late this year(8000LBS). First impression,not good---maybe i guess,with just EDM1. 5's, comp box turned OFF i could hit 1200 preturbo at about mid throttle going up a average hill,anyone know if this is correct. I'm thinking about maybe selling this turbo and going with a regular B1-2. I am also going to sell the comp and go with Bob/Marco CATCHER ecm. On level ground i was about 750-800 post/1000pre,does this sound to hot ,it is to me ,not much room left for passing on a grade(not suppost to go above 1200pre right). Piers says to go with a B1-2/wastegated tow version,--- you have the wrong turbo. Without towing ,comp on 2x3 i can pin the 35lbs boost guage and hit 1200-1300 pretty quick rowing through the gears. If i was not interested in towing,maybe this turbo would work cause it lights pretty fast but put on a good load behind it and it gets hot fast. Tell me if it should stay or sell. THANKS DW :confused: :confused:
David, the ecm's did leave here today. so maybe hold on for a couple of weeks to see how much the catcher helps.
If not there is time :)
Thanks Bob,I'll hold off on the turbo/high egt's problems till later,hopefully the Catcher will help ,PM me with a price for all the goddies when they are ready to ship and i'll courrier the check asap. PS--- i'll see how hot see gets with the 1. 5's and the Catcher,my wish list is edm's2. 4/Catcher and have the proper charger,hopefully i can get it right around spring time---see ya DW :)
David,
The exhaust housing is too tight for towing..... Actually I feel it is too tight for about any truck with the fuel turned up. The turbo Piers suggested would work good or you might even consider going with a full B-1 that is wastegated. Backpressure plays a big role with egt issues, thus one of the reasons for a wastegate. Remember that higher boost doesn't always equal more HP or ability to control egts. I have seen an HY-35 make almost 50 psi boost but boy was it hot. With the B-1 I am running I have it wastegated for 35-40 psi.
Doug
Thanks for the info Doug,so do you think i SHOULD go with the regular B1 or the B1tow,this hopefully will be the last turbo i buy(I thought this was it when i bought this kwspoolB1b-2---BAD ADVICE I TOOK :( ). As i said before,comp is gone soon(don't like the advanced timing and stress on the vp44 while towing-don't use it much anyway)Doug/Marco Catcher will be installed and i'll try the new turbo with the 1. 5EDM's that i have already but may go bigger--to 2. 4s. Will i have enough fuel to spool either B1,i don't want it to be to laggy. I guess i am trying to find the middle of the road here,i want a awsome tow rig that can pull most grades at or close to the speed limit and still be able to pass if needed,aswell as be able to hot rod it a bit once in a while. Believe me this truck has not been driven hard- its a hobbie truck,comp has not been passed 3x3 or has it driven faster than 85mph---only 21500 kms on it(13500)miles. Thanks for your expertise,i think my pocket book is going to get much lighter again. :eek: :eek: :eek:---PS If i can really aford it one day i may get Piers to do his magic with a cam and 2stage/o ring head work but that is a big wish---first things first--DW
