Following on to a long path of getting my 12V to run great again I did a leak down RATE TEST on my 12 valve because it hasn't been running up to par and this was the next step after going through the fuel system.
Results are below - this is the average of 3 meaurements (really more 3 repeatable measurements of the same value on each cylinder), at 100PSI, with piston at TDC for each cylinder, using a MAC leakdown tester:
#1: 4%
#4: 24% - audibly louder than the others, sounds like it is coming out the intake valve listening through the intake manifold.
#2: 10%
#6: 11%
#3: 7%
#5: 16%
The fact that they go from 4% to 24% and audibly much louder on #4 leads me to believe this could be my problem, or at least the leakage rate would be concerning of a valve problem on the verge of getting worse quickly.
I'm inclined to pull the head to at least have a known good baseline understanding on the mechanical condition.
Any words of wisdom or thoughts on this would be greatly appreaciated.
(this is the fuel system path I had followed before this) thought this deserved a separate thread as it is valve/head specific issue: https://www.turbodieselregister.com/threads/something-not-good-has-happened-
to-my-cummins.259570/#post-2523835
#1: 4%
#2: 10%
#6: 11%
#3: 7%
#5: 16%
