2nd Gen Non-Engine/Transmission Leveling kit and bump stops
For those who have installed d25 springs to level, did you replace the bump stops? If so what size and from who?
Dave
If your shocks are the proper length, you should be ok with the stock bumpstops in terms of the axle not hitting into the frame/engine, etc.
DShuart said:
I forgot to add that I am installing Bilstein 5100's so I am thinking of going with 3 1/2 " bump stops. Any thoughts?
Measure the available travel on the shock shaft,compare that to the distance to the bump stop. Then allow for how much the bumpstop will give.
Bob
