Archived lift pump replacement
Archived 98 12v CTD won't turn over
Archived blew trans on Chicago toll way
Slight leak in the fuel line allowing air in? I had that happen in my '97 3500. One place to look is the preheater. It is under vacuum from the lift pump.
I replaced all rubber lines and took off fuel heater finally got good pressure i pinched off return line and pressure goes to 60psi idle its at 23 and when i rev it up it drops then comes back up to around 29 power seems to be better adjusted the overflow valve in prety good. I was pinching of the wrong hose before for the return but from doing this i understand alot more thanks for help.
