I just relocated my lift pump to the frame rail just ahead of the fuel tank with the Vulcan Relocation Kit from Geno's. I went with the factory lift pump for price and availability concerns. Pressure at idle is, I guess (16 pound guage) 17 psi. Cruising is 15 psi (2 psi less than idle), WOT 13 psi with EZ at level 1. Haven't tested with EZ set higher yet. Yes, I am very happy with these pressures.
What I really want to know, from anyone who has relocated the lift pump - factory, FASS, Glacial, or any other type, has there been any problems with pump operation or fuel flow in cold temperatures? I know it sounds a little strange, but that 1100 pound heater the lift pump was mounted on previously may have helped things during the cold. I realize that after a few minutes, heated fuel is returning to the tank and warming things up. Has anyone had the need for a heater at the relocated lift pump?
