I 2nd the seal that HH suggested... I buy them straight from Seals-It and they work! We use them in rockcrawlers and mud trucks and are amazing... . not very expensive and will work with up to 40 spline axle and as small as 30 spl
Thanks for that. . Will pass it along to the installer with all the other stuff that has been sent. Hopefully it helps someone else that's struggling with a front axle leak too.
These forums are fantastic when people help each other and refrain from the nasty personal stuff. . Tnx. .
To help center axle shaft in tube/seal for install I use a prybar in end of axle tube (rounded side up) to lever the inner end up and gently center itself through seal. Use lots of grease on splines and on shaft where it will be touching seal on way through.
