Looking for 160psi electrical gauge
Where to purchase Alcoa 16" wheels
injector puller
Want to monitor transmission lube circuit psi full time.
Would like 0 -160, looking for electrical with really quality sending unit.
Already talked to Westach, in electricals they only go to 120psi, then to 500psi in the next step.
Already have done the TDR search.
Already have done the GOOGLE search.
Have seen 0-200psi oil mechanicals which might be the end result.
Suggestions?
I don't know if 150 psi is 'close enough', but dakota digital www.dakotadigital.com sells pressure gauges that go to 150 psi. I have their 0-30 psi fuel pressure gauge and have been happy with it.
Good Luck,
Mike
SPA makes what you want. Call HVAC or Brandon to get it. You could go with a dual SPA too and monitor another pressure or temp or just about anything you want.
