Engine/Transmission (1998.5 - 2002) Looking for a good shop in PA/NJ/NY/DE area
Engine/Transmission (1998.5 - 2002) Need Some Help with 2 Issues
Engine/Transmission (1998.5 - 2002) Fan shroud modification??
MMoyle
I am looking for a good shop to install my vulcan performance pusher pump system and draw straw V setup. I currently have the dealer installed in-tank setup with the original carter pump on the block. The setup worked well for years, but the in-tank pump appears to be dead and I am only running on the carter pump at the moment. If I jump on the throttle, I can almost push the fuel pressure down to zero. So I am taking it easy on the truck until I can get this installed.
I already purchased all vulcan pusher pump and draw straw V setup, so I can looking for someone to install it. I have never done an install like this before so I am a little nervous tackling this job on my own.
Any one know of a good shop in PA/NJ/NY/DE that could help me with the above? Or maybe a TDR member that could help me perform the installation? I am willing to drive and pay someone a fair wage to help me with the installation. I need to get this done soon before my VP44 dies due to lack of pressure.
Mike
Hi Mike
I'm an Air Dog dealer and could probably help you out. Have same truck as you only 2001 which I installed a complete system with draw straw. Located in the Levittown Pa. aera. If I can help give me a call. 215-788-1107
Thanks Clayton
