Looking for a source of IntelliPower PD9180 converter
Heads up on some bad tires.....
custom Tailgate
I am going to change out my converter to a Progressive Dynamics IntelliPower PD9180 and the PD9105 Charge Wizard. I have searched the internet with google it did not turn up much for sources (only 1). I need sources to shop and compare prices.
Thanks,
Bob Weis
Thanks,
Last night I surfed for about a couple of hours trying to find the best prices on the IntelliPower PD9180 & PD9105.
That's the same thing I found that www.bestconverter.com had the best prices and they still add the charge wizard for free.
Thanks again,
Bob Weis
Bob-
As a last recommendation, make sure the charger you pick will be able to fit in the place that you have in mind. Additionally, they have a built-in fan, so it should have adequate ventallation. If things haven't changed, these were the following dimensions:
Model PD-9130, 30 Amp dimensions: 4. 5'' x 7'' x 7. 25'' 4. 0 lbs.
Model PD-9140, 40 Amp dimensions: 4. 5'' x 10'' x 7. 25'' 5. 4 lbs.
Model PD-9145, 45 Amp dimensions: 4. 5'' x 10'' x 7. 25'' 5. 4 lbs.
Model PD-9155, 55 Amp dimensions: 4. 5'' x 10'' x 7. 25'' 5. 4 lbs.
Model PD-9160, 60 Amp dimensions: 3. 6'' x 8'' x 9. 00'' 5. 8 lbs.
Model PD-9180, 80 Amp dimensions: 3. 6'' x 11'' x 9. 00'' 7. 5 lbs.
