Low Heat Output from vents.
Rear Wheel well Fender Liners
Trac Contrl Light on
If you can read my chicken scratch there are two resets.
So, just tried the "reset" all it does is reboot the radio. No movement of the blend door actuators. I held the power and enter button for about 15 seconds and then the radio stared it's reboot process. No change in the servos or any movement. Has anyone actually seen the servos move on a radio/head unit "reset"?
I have only seen this work on a 2010 ram with hemi. I also tried this on my 2018 hemi, no change, my 2015 CTD, no change and my 2014 no change. All different radios, same procedure. (I think?)
Laxcoach
Laxcoach
Hold for full 30 seconds. The screen will blink on & off several times.
Laxcoach
I can say for sure it made my heater work much better
Yup, did that exact procedure and yes after 30 seconds the radio will start flashing on and off, but on the reboot it does not actuate the servos. In fact the reset of the head unit only reboots the radio. I have now tried this on 3 trucks (2014, 2015, 2018) and non of then "sync the servos" I don't think this is really a thing that happens. (Maybe in years prior to 2014, as I did see it happen on a 2010) I have watched the blend door and listened for any noise on all 3 trucks and nada, nothing. So if you have actually seen this work on your own truck and know for a fact that the servos move after the reset I would be interested to know that.
Thanks!
Laxcoach
My wife's 2013 2500 (it has the dual climate control) is having this issue as well. She gets a little bit of heat out of the passenger's side and none on the driver's side. I just did the HVAC head reset and used AlfaOBD to do the actuator calibration test. It said that all 4 passed. Unfortunately, her truck was cold when I did all of that so I have no idea if this worked on not. If she doesn't go anywhere this evening, I know that she's heading out of town tomorrow for a few days and I'll find out then.
ETA: I just took it to refuel and it helped only slightly. Still not what it should be.
2013 Ram 2500 Laramie QC LB 4x4, Thuren Fabrication adjustable track bar, sway bar kit, and 2" leveling kit, Bilstein 5100 shocks, Westin Chrome Ultimate Bull Bar, Weatherguard Saddle Box, Line-X Bed Liner, Cooper Discoverer AT3 XLT's LT315/70/R17
