Does anyone know the Cummins part numbers for the lift pump test kit. I want the adapters to check for areation of the fuel, inlet restriction, pressure, flow and any other test that Cummins does. I would also like the pressure transducer that Cummins uses so I can monitor fuel pressure while driving. Also does anyone know what the part number for the Cummins book that lists all the above test and how to perform them and what the specs are. Thank you.
