Maybe some of you have experienced the same problem I am having. Have a 94' 4x4 ... . just did the whole front end top to bottom... springs,shocks,ball joints,universal joints,wheel bearings,all steering linkage,all bushings,dss,alignment, even all new bolts and nuts. Before all this I installed a thuren track bar... . truck was fine but sloppy. While I was freshining up the front end I figured now is a good time to put a Mag Hytec on the Dana 60.
Truck rides fantastic... . except when I go over a decent size dip in the road the BIG bolt on the Thuren track bar that attaches to the frame hits the top of the diff cover... . quite hard...
I can see a wear mark. Never happened with the stock cover. This happen to anybody else?? What are my options?? I cant live with it and sooner or later I'm gonna hit a dip I dont see and its gonna crack it.
Grind the bolt down??
Longer bumpstops??
Scrap the Mag Hytec and get like a Dynatrac cover or something??
Opinions and thoughts appreciated ... . Thanks
Longer bumpstops??
