Oilman(Kevin)
Why don't you tell the story correctly when you state testing of lubricants and then compare your LE with another brand?
The SRV wear test paramiters (ASTM D 5707) is a Standard Test Method for measuring friction and wear Properties of LUBRICATING GREASE using a High-Frequency, Leinear-Oscillation (SRV)Test Machine. It has NOTHING to do with GEAR LUBES! GEAR LUBES are tested differently, and YOU should now that!
In general, the SRV (ASTM D 5707)test simulates the conditions found in a universal joint of a vehicle, high frequency, linear-oscillation motion. This is quite dissimilar to most situations where a gear lubricant is used, including the differential of a truck.
The test you should use to compare gear lubes is the 4-Ball ASTM D4172 and not a test that is designed for grease!
Wayne
amsoilman
94'SLT 4X4 AT/White in color. Factory Tow Hooks & Running Boards. Amsoil By-Pass filter, Amsoil Air cleaner,and all fluids are Amsoil. Optima "Red Top" batteries.
BD exhaust Brake, BD Torque Lock, BD Torque Converter, Dr. Performance Stage II Injection Pump. Mag-Hytec Diff Cover,Mag-Hytec Transmission Pan, Isspro Pyro, Boost,Oil temp Gauges mounted in 3 Gauge post mount. One gauge monitors Engine Oil, Trans, Diff. Temps.
Wayne
amsoilman
