amsoilman
Staff Alumni
Oilman(Kevin)
Why don't you tell the story correctly when you state testing of lubricants and then compare your LE with another brand?
The SRV wear test paramiters (ASTM D 5707) is a Standard Test Method for measuring friction and wear Properties of LUBRICATING GREASE using a High-Frequency, Leinear-Oscillation (SRV)Test Machine. It has NOTHING to do with GEAR LUBES! GEAR LUBES are tested differently, and YOU should now that!
In general, the SRV (ASTM D 5707)test simulates the conditions found in a universal joint of a vehicle, high frequency, linear-oscillation motion. This is quite dissimilar to most situations where a gear lubricant is used, including the differential of a truck.
The test you should use to compare gear lubes is the 4-Ball ASTM D4172 and not a test that is designed for grease!
Wayne
amsoilman
94'SLT 4X4 AT/White in color. Factory Tow Hooks & Running Boards. Amsoil By-Pass filter, Amsoil Air cleaner,and all fluids are Amsoil. Optima "Red Top" batteries.
BD exhaust Brake, BD Torque Lock, BD Torque Converter, Dr. Performance Stage II Injection Pump. Mag-Hytec Diff Cover,Mag-Hytec Transmission Pan, Isspro Pyro, Boost,Oil temp Gauges mounted in 3 Gauge post mount. One gauge monitors Engine Oil, Trans, Diff. Temps.
Wayne
amsoilman
