So I finally got around to finishing (at least of now) my engine upgrades. I wanted to be able to "safely" run the smarty on level 9 everyday. I'm doing a little "testing" and on a WOT run this morning I got the rpms to about 3500 between shifts. Smarty is set on level 9, stock PR, rpms & TM, 2 timing. Shift enhancer on daily. Boost was about 33-34, egts about 1100. So would this be considered "stock" rpms and if not why is it into the red with the smarty set to stock rpms? And the main quesiton, do I need spring? When I did the cam install Piers Harry and PDR said I didn't need springs if I didn't run over stock rpms or excessive boost, so I didn't do them.
