Hey folks, I have a 2019 tradesman crew cab diesel with a max tow rate of 19k. I am in the process of setting it up to bumper pull every bit of that, albeit not that often. I have a 20k bumper pull dump trailer I will be using for various projects. I want to be able to pull it with the aev lift and rim/tires combo eventually when the 2019+ kit is released which I know retains the factory specs but I also want to do it safely and confidently. I am looking for recommendations on towing kit I can use with the aev setup. Weight distributing hitch, helper springs, etc. any help would be greatly appreciated as I don’t want to swap out hitches when I put on the aev stuff down the road.
thanks much
thanks much
