Maximum Dual Tire Size
Front brake upgrades?
Edge won't work for me, what else?
What is the maximum tire size that will work on stock 17 in wheels on an 08
3500 DRW. After 6 years or more of 17 in truck tires there are still NO heavy lug tires available in the stock 235/80 size.
Your new tires need to be designed to fit the rim width, and not touch each other at the bottom under load... . tires rubbing together will cause them to heat and fail...
Hope this helps...
265/70/17 Copper M/T here also. The guys running 315's are running 2" leveling spacers up front and 2" spacers between the duals. The 265/70/17 are very close to oem in height just a little wider.
dlmartin-
So I have researched this topic for some time now and decided to give the 265-70's a try. Note: I didnt use spacers because I have concerns of added pressure to the hub based upon the weight I usually pull. The tires have enough spacing between the duals and seem to work ok with the weight I am pulling. The spacing is tight so I am running 55 psi per tire to keep them from rubbing. I do have some abnormal tire wear because the tires are too wide for the wheel width. I will probably rotate a lot so I can keep the wear to a minimum. Most likely when these wear out I will probably go with a 245 or 255 to decrease some of the tire width. I can tell you the 265's look awesome compared to the 235 "pizza cutters" that come on the stock trucks. Note: BFG has some 255's coming out that should start shipping in January (according to Discount Tire). I think 255 would be the perfect tire however these new BFG tires look like mudders which wont work for me as most of my driving is around town. I do go off-road during the hunting season which is one of the reason I went with a little more aggressive tread as I have been stuck a couple of times. Good luck with your research and remember this is MY . 02!!!
Southbound
