COBRAJET said:Not to change the subject... but 95 degrees and 90% humidity never exists. The heat index if possible would be over 140 degrees. 95 degrees with a heat index of 105 would be around 50% humidity. It is very difficult to have temps rise without a lowering of the humidity. It is the most humid early in the morning since the temps usually fall at or just above dewpoint which is as humid as it gets. A heat index of 105 is very uncomfortable.
COBRAJET said:The very dry climate in AZ. is helping your AC out quite a bit. It is a lot easier to cool dry air. It is a lot easier to heat it as well. You are 110-115 in the daytime and still fall into the upper to mid seventies at night. It was 104 here today with a low of only 83... hotter than that in the city. You are getting a nice 30-35 degree swing. We are lucky to get 20... high humidity. The temp can not fall below dewpoint so we wake up to nice muggy mornings... working the AC right off the bat.
Kday said:I've got a 05 QC and I noticed that after I put in the Rokktech advanced timing sensor the A/C compressor would stay engaged longer (not sure of vent temps but I'll check). I'm not sure I'm on track with this but I know it made a difference on mine, maybe someone who knows more than me will chime in. I'm not going to debate temps vs. humidity here but it's plenty hot here in S. E Florida. Good luck on a fix, Ryan.
JWilmer said:OK... went on a "family day" yesterday (alot of stops... alot of open doors... alot of dilly-dallying with 2 young boys)..... heat index was 106 degrees here in MN. (warm enough I think)... full cold... on recirc... . fan on #3... wife complained about being to cold... turned fan to #2... I was OK... still getting low 50's from the center vent... . wife turned her vents up and away (still too cold) wife misses the dual climate control the Chevy had... . kids were fine in back.
AGAIN... I cant complain about mine... . its NOT the coldest A/C I've seen... but it is plenty cool for me and my family... IMHO... .
This was the hottest test temp to date... will leave it alone for now... it did well enough not to mess with it..... BJ
