They are going too far in the housing. The fix is to add a screw to stop the door in the proper spot. If it breaks now, you are going to get a new housing with a moulded in stop.
The way the system works is the motor drives the door each way until it stalls. The stall point is the stop that the motor remembers. It calibrates each time the key is turned on. So you need a good hard stop for the system to work.
