Hi guys,
I don't get much opportunity to visit here, sorry to say.
Anyhow, we may purchase a 34 - 36 ft Toy Hauler, and because my 99 Dually has a 3:55 rear end, I'll need more power. Right now, it's got 4" SS Exhaust Turbo to Tailpipe, and AFE Mega Cannon, and an Edge EZ. It's fine, but even with our current trailer, I noticed a lack of pulling power in the 2000 - 2100 rpm
band going up long hills. I need to mention it's an auto trans, but with a triple disc torque converter and a DTT valve body and other mods.
So I phoned Banks and here's their suggestion:
High Ram Air Inlet Casting
Banks' streamlined, cast-metal High-Ram air inlet replaces the factory's smaller, angular piece for a 56% reduction in pressure loss. Greater boost on the intake side-without increased backpressure at the turbine-makes the engine more responsive and fuel-efficient.
Quick Turbo Assembly
Banks developed the Quick-Turbo in conjunction with the Holset turbocharger and Cummins Engine companies, to eliminate sluggishness "out of the hole" and produce strong acceleration. Quick-Turbo produces massive torque right from idle, achieves a higher peak faster, maintains more boost through the powerband, and doesn't over-boost. Banks' exclusive BigHead® wastegate actuator prevents "wastegate blow-open" by keeping the valve seated at higher pressures, increasing mid-range torque and top-end power.
Big Hoss Diesel Tuner *High Powered Version
* High Powered version capable to be programmed to the following Levels.
Level 1 50hp/115 lb-ft
Level 2 75 / 193
Level 3 100 / 238
Level 4 130 / 262
Level 5 160 / 317
A three part solution from Banks.
Two questions come immediately to mind:
1. Because I had Cummins replace the Bosch VP44 with a Viton sealed one last fall, I don't want to overstress this one, so I'm wondering if this will do that.
2. I'm surprised Banks didn't suggest an injector change. They do have a good reputation for engineering solutions instead of just piling on parts that don't play well together, but I was curious was some of you more knowledgeable gearheads thought of this.
They said to remove the Edge EZ, and install the other stuff, my engine breathes fine the way it is for the mods.
So I was wondering what you guys thought of this proposal and whether any of the other members was using this combo.
Thanks,
Robert
Level 2 75 / 193
Level 3 100 / 238
Level 4 130 / 262
Level 5 160 / 317
Thanks,
Robert
