Before we go tossing this motor to the curb... ...
What did the cylinder walls look like when you had the head off?
When you say they checked the head, did they flux it to make sure it was not cracked?
I am assuming you used stock head bolts? What did you trq them to? (Not trying to insult you) Did you trq them in the correct sequence?
Moving onto the clutch:
Whos clutch was it? If it only had 200 miles on it, the pressure plate should have been covered under warranty. I may be able to help you on that depending on whos clutch it is.
If you want to call me, ask Scott for my number he has it.
Best of luck
Chris
Cylinder walls still had original cross hatching. I did have the head magna-fluxed and was told no cracks were present. I did use stock head bolts and torqued them in sequence to 66 ft-lbs, Long bolts in sequence to 89 ft-lbs then an additional 90 degrees in sequence. As i stated in my original post my truck only has 139,000 on it. Had a transmission shop replace clutch so I do not know who the manufacture of the clutch was. I did not mention this but during first replacement of head gasket vehicle had set for approximately one year. The reason for this was had to purchase parts and have machine work done as money became available.
