Does anyone know anything about the wild rails from T&C Diesel? Thinking about getting them for my truck. Is it worth installing?
Yes, I did mine about a week ago. Noticable diff. and cheaper than a dual feed fuel line. Todd has been a huge help to me with this, and with a seperate problem that I am having with truck. Todd And Chris Are knowlegable and willing to help.
Something I would like to know is how does the Modified Fuel Rail supply more fuel with only the stock feed line to feed it, you can only put so much fuel through that very small tube from the CP3.![]()
The CP3 pump runs at the RPM as the crank 1 to 1.
John
John
Does diesel fuel compress? No, so what ever is leaving the rail has to be replaced with the same amount form the CP3. The rail is not like a air tank that has storage because fuel can not compress. The only thing that I can see the modded rail doing is increase flow. Cause if you are draining your rail pressure, and you mod your rail your, and do nothing else, your saying that it will support more HP?
The Cp3 is NOT capable of a constant supply, its done in waves or pulses, under extreme Pressure. . lengthen the wave or the Pulse. the entire system pass the Pump is affected. .
How are you lengthening the wave or the pulse by modding the rail? Plus not sure what you really mean?
My point on the situation is, liquid (diesel fuel) does not compress, so no matter how big of rail you have, what ever fuel leaves the rail has to be replaced by the CP3 pump, if it comes in pulses, waves or what ever. So if your CP3 can't support the mods you have, by changing the rail is not going to give you increased capacity.
I could see that it could give you a little better flow.
Its a distribution center, Not a storage center, except when off.
