KO Engineering makes the RASP. DTT and Ollie Poole (
www.Powerbypoole.com) are distributors.
This afternoons data
It was 98 under the hood before engine start, 3/4 tank full.
Condition,VP Fuel inlet, VP electronics, VP Return banjo, VP body 1" down from electronics and about 1/2" forward, mileage, OAT
65mph,122,117,120,127,55843,98
stop/go,126,123,123,134,55853
65mph,135,131,130,140,55871
A/C on,151,150,137,152,55875
A/C off,130,128,126,138,55879
Why would the A/C on make such a diference? Gary, can you do some A/C on, off? What's up with that?
I think I shot the fuel inlet better today, but I now think all I am getting is the body of the VP at the inlet represented in the inlet swivel fitting not the incomming fuel temp.
I would guess there is a general VP body temp rise to about 140* unloaded. Loaded it probably would be higher. Electronic bay seems to be about 130* - 135*.
I would guess that as long as there is at least 1/2 tank, the tank will heat sink return fuel ok. Less than 1/2 tank the fuel will not cool as well, as the tank fuel will not throw off the VP heat and the fuel will get hotter and hotter.
It may be more important to cool down the VP than the turbo although both cool down together (assuming 1/2 tank + fuel)
Tommorrow and next day are plumbing days so next reading from me will have RASP, inline cooler, tank vent pipe return for VP.
Not real clear data, but I put the data exactely as recorded. Cooler installed data should be interesting to compare.
Bob Weis
