Greg - looks like you were typing your post as I was sending mine!
Texas Diesel said:The problem with what you are doing is that you are reading surface temperature which has very little correlation to internal temperature, which is where the electronics live.
Surface temperature will vary considerably but internal temperature is what kills the little hunks of refined sand.
Heat will flow or properly be "sinked" away from the hot side to the cool side. What you are doing is like takeing the temperature of the surface of the radiator and useing that as an indicator of cylinder head temperature. Which it is sort of via conducted heat (coolant flow) but will not be very accurate. You are only getting a very rough / crude estimate of VP-44 internal temp.
As I mentioned in an earlier post, the only way to cool the VP-44 is to continue fuel flow after shut down. Question is 1. how? and 2. How long? #2 can be answered by time lapse readings (every 5 minutes) untill temp stabalizes.
