The only reason for the dual relay was to flash the lights with a single switch wether the tail/marker lights were on or off. That was the only reason and I first did it to save wear on the OEM light switch.
Paul, when you hooked up your relay, you did it right out of the OEM light switch. It needs to be tapped in just before the tail light feed for the trailer relay, then the dash lights and front parking lights won't be activated by the add on. In addition the way the system is constructed, if the a relay or the switch fails, the lights will work as the truck was built
Sorry for the confusion, not being a 'puter person I didn't realize the drawing would be so hard to read when scanned.
FYI Northwest Power Products has the relays, 30 amp p/n 29-939 and 40 amp p/n 29-940 on web at WranglerNW.com.
Denny
Denny
