The 03 in my sig has several quirks and I decided to see if anyone else has them.
1. While cruising on the interstate or highway speeds 70-80 MPH 6th gear RPM's 2000-2350 my truck will completely cut out for a second or two then come back and go back to the prior speed. It happens with or without cruise control on and only happens with Juice set on anything other than 0. I just had the Juice sent in for HOT upgrade and it checked out OK. Also this only occurs after truck has run for at least 20-30 minutes. It also did not occur when temps were below 10' F.
2. When I come to a stop after my truck is completely warmed up my truck will try to idle at anything from 1100-750 RPM's. A hard push on the brakes slows the engine back to normal idle speed.
I've learned to accept these quirks but was wondering if anyone else experiences them.
