steved said:Ain't that the truth... I've seen guys pushing over 300 watts out of Connex 4600s and it only make the seatbelt light flicker... it doesn't affect the way the truck runs... although, that's pretty funny... imagine doing that to SOMEONE ELSE'S truck that's sitting beside you!!
Troll said:You may be able to solve your problem by sheilding your radio or the affected boxes with copper screen. It will not transmit radio frequency and is a well known sheilding device. (try sitting in a copper screen box and use a cell phone, won't work).
Yup, it's magnet mount, on the roof.qzilla said:Also how do you have your antennae hooked up? I have seen a lot of problems with antennaes. The worst ones are the magnetic style ones that go on the roof or bed rails. They can cause havoc on a lot of things.
I sent an email to technical before I posted here. Friday night. I assumed it would be Monday morning at the earliest before I got a response. I just figured if I had to spend a bunch of money on a new box, I'd be better off with a box that had no RF issues. I'm not posting to bust anybodies chops, I was just having trouble and fishing for answers.qzilla said:Why don't you call us and get the board swapped to the later version that has some extra RF protection built into it?
I haven't had the Quad long (EZ convert) and just put my CB in. I probably skipped that thread since it didn't pertain to me at that time.qzilla said:We made several post months ago on several different sites telling people that if they had a CB issue we were happy to swap it out with a new board?
No, you misunderstood. The XM, the CB, anything to keep your mind engaged while putting down 1000 miles a day. The XM has talk radio, news stations etc ... ... ... ... you can only listen to so much music.qzilla said:I am not sure what the XM radio has to do with any of it? I have never heard of an XM causing any trouble for anyone.
My EGT gage is not effected. It's a Hewitt I believe, or SW? It's rebadged for Enterprise Engine Performance here locally.qzilla said:Also just so you guys know with these CB's that have RF issues. This is going to affect an EGT gauge as well as other things you may add to your truck.
Like I stated earlier, I haul horses all over the lower 48, plus Alaska and use a gooseneck. That limits my mounting locations.BK said:Try an antenna on the bumper.
As stated earlier, that's where I'm powered from.BK said:Run the power from the driver's side battery.
From the CB itself.BK said:Is that 40w from the CB itself, or is there a seperate heater?
I bought this radio off Ebay and had a local dude go through it. He verified what I bought and tuned it a bit. I'll go back to him and see what he has to say.BK said:The EMI filters built in the CBs are NOT designed to take the additional current to run heavier finals in the rigs. The coil(s) in the DC input filter will saturate with the additional current from bigger finals.
I've read a little before buying my 1st CB, and read that direct battery power was the best?jnelson said:Just wire your power thru the fuse box and all will fair well.
I've never been a fan of the TST, and I really like the simplicity of the Quad and use of my analog gages.BIG BOB said:TST and a Juice I know will work fine.
BK said:It's fine to do things to reduce the susceptibility of a device, but it's best to tame the source.
steved said:I highly doubt he is doing 40 watts dead key on a 29. Most likely it is similar to my old piece and doing about 8 watts dead key and swinging 40 watts (the reason the modulation changes the trucks running characteristics)...
qzilla said:Throw a 40 watter in the cab and a magentic stick on antennae and let us all know how that works out.
The bottom line is that with poor RF filtering a powerful CB can be a destructive little device.
qzilla said:Half of it is probably the magentic antennae.
Try taking the antennae of the roof and see if the problem quits. Just leave it un attched but hooked up.
You may want to go with a normal antennae, it seems the magnetic ones do something to the ground plane in the truck.
THarris said:Get a amateur license. run up to a kilowatt, legally, mobile
JHardwick said:If the 40w messes with the Quad, do you think 100w will, 3500w? I checked back today with the dude who went through it ... ... ... . I bought it tuned up and he verified everything was up to snuff.
Again, this is not a slam on Quad. But he did say that the plastic box was a problem. If it was steel, or wrapped in aluminum duct tape and could be grounded, the problem would disperse.
I dunno, I like my Quad and so far like my Cobra, but they don't play well with each other :{
BK said:I hear ya, again, in the real world there are standards products and sub components need to meet for susceptibility. . and then there's standards for how much crap the other items can produce.
For the commercial world its FCC 22, mil it's 461.
If all goes well, all play well together. As you say , Quad made changes to decrease their susceptibility. . but what if you get a new box from Quad and you still have problems, or problems with a new toy you install?
I know you went back to this guy, but sorry.
Even many technical folks dont understand emi filtering and magnetics.
I dont think your CB guru could even tell you what material should be use for a diff choke vs a common mode choke, never mind how and why to select the cross sectional area, or even how to wind one and why.
Shot me a pix of the inside of the rig, particulalry the area the 12vdc is entering. I'll be able to tell if anyone bothered to increase the line filtering.
Stock form they are only designed to deal with the current from developing 4w of output power. not 40.
I'll bet no attention was paid to the input filter. I have never heard a "tech" modifying rigs even discuss input filtering and modifying it. It seems they just have no idea. . they think it's there only to keep alternator whine out.
Again, if you don't want to bother with that, but want to prove it to yourself, power the rig from another freshly charge car battery sitting on the ground and not connected to your truck and see what happens. Remove any local grouds you put in at the rig.
I'm betting it's a conducted problem... the rf back onto the 12vdc bus.
