Update on the main bearing fiasco, Installed new main bearing, torqued to 60,97 newton meters then on the final torque I got side tracted and ran the torque wrench up to 175 like I should have only I got on the ftlbs scale. well stuff happens, I ordered two new bolts put them in, reninstalled engine in truck, new clutch and pressure plate, put trans in and trasfercase.
The final result is a vibration at all engine speeds, and the clutch raises heck at idle. If you push in the clutch pedle, the clutch noise goes away. My theory on the clutch noise is my new disk has large springs in the center and the old one had spall, mix that with a vibration and that poduces noise.
I cannot place the cause of the engine vibration tho, I cracked all the fuel lines and each cylinder is contributing, it almost runs like it did when it sheared the shaft off in the pump head. Does anyone have any ideas as to what is going on here? does the harmonic balance have to be timed? Thank you Jon
